Need help
Leonid
Canada
5.7 v8
Hi all. 2013 ram 1500 sport. The front right headlight stopped working, I changed the bulbs, it didn't help. Also, the radio control and climate control under it on the central panel stopped working. The radio is controlled from the steering wheel, and the climate through the touch screen. Maybe someone has encountered such a problem? Thanks in advance.
tron67j
Maryland
For the headlight, unplug the bulb and use a voltmeter to test the circuit. If no power you need to check all the wires back to the fuse box. Check them for continuity. If all okay then check from fuse box to switch.
