Need Help!
gochiefs1976
Can anyone help on what I can do for my 2012 Ram, the tilt wheel will adjust up and down and stays unless I lift up on the wheel then it clicks and will lift up. It will not lock in place and moves while driving.
Raist11
Canada
It's a little confusing. It will adjust up and down and stays in position unless you lift up on it and it clicks, then it will move. But at the same time it also won't stay put? Perhaps if you clear things up a bit, you may get some more responses.
7777xm
Covington, GA
Im a little confused, but if its not locking and can be moved while driving when it should be locked, then there is something broken. It could be a simple fix, or complex, depending on your skill level. If you are not comfortable, and dont know how steering wheels and columns work, take it in to shop, or dealer, if still under warranty, and get it fixed.
