Need Immediate Help
Tolson93
Tolson93
Northern MN
Well guys I have been looking at dealerships for over a month and I can't get approved for anything due to my credit.. I'm 20 so I don't have much established yet and owe to much on this truck to trade off there'd be lots of negative equity... So I think I am going to my bank ASAP to take out a couple grand so I can get everything fixed up my front end first ... My front brakes are squealing and grinding really bad and it clunks up there really bad. So I'm just gonna monitor the oil and keep it full for now and just keep putting money away until I can afford to have it looked at and fixed or whatever the issue may be
MyOhFive
HEMI
Just a thought... you may be bette off addressing the engine first. Would suck to put those front end parts into it and have the motor pop...
btw your front end clunking I'll bet is sway bar bushings.. maybe links. Either way, less than $100 from rockauto.com installed yourself.
Brakes too, order the parts online, buy a Haynes manual and change em yourself. Not hard and definitely don't need a $2000 loan from the bank brotha!
Tolson93
Tolson93
Northern MN
I'm not sure what the issue is oil has been fine and it doesn't even smoke
MyOhFive
HEMI
Well if it's holding then you may have gotten lucky. Keep checking her every 100 miles and see my edit up there ^
Tolson93
Tolson93
Northern MN
It's only been like two-three weeks on the oil but I keep checking it. And thanks for the tips!
MyOhFive
HEMI
Question. What viscosity you running?
Tolson93
Tolson93
Northern MN
ImageUploadedByTapatalk1400470770.038978.jpgImageUploadedByTapatalk1400470780.187709.jpg couple pics I got from underneath my truck. Was little wet I blasted with brake cleaner to try and clean some off.
Tolson93
Tolson93
Northern MN
Well had a shop look at my front end (I know I should be looking into the oil issue, but this shop looked at my front end for free) they said my seal where the inner tie rod goes into the rack is bad and leaking so now I know where my leak is .. And just my front brakes. What a relief I thought it was going to be ball joints and a bunch of other things
MyOhFive
HEMI
Yea.... but did they quote you on the rack? Not cheap...
Tolson93
Tolson93
Northern MN
Be like 800$ for brakes and that rack
Tolson93
Tolson93
Northern MN
Got my oil changed and think they put in 10w30 when I told them 5w30... Any major differences between the oil weight ? Good or bad? Or probably doesn't matter
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
Shouldn't hurt since the weather is warm. It would be different if you had the MDS system like I have on my 07' ram. Just change to 5W30 on your next oil change.
Tolson93
Tolson93
Northern MN
I had them add some Lucas oil stabilizer to see if that might help with my oil usage issue
Tolson93
Tolson93
Northern MN
Not sure if it's snake oil or actually works but guess I'll find out!
Tolson93
Tolson93
Northern MN
Ever since Tha oil change and the Lucas stuff I have the lifter noise or Hemi tick even worse now..
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Are you getting any misfire codes?
Tolson93
Tolson93
Northern MN
Nope runs like normal. Just noticing before it warms up that tick seems to be a little louder... Always heard it but wasn't to noticeable ... I heard it this morning inside the cab when I would left off the gas and start slowing down even a little.
joshhhh
