Need Immediate Help
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I say valve guide seals or possibly a bad PCV valve.
Tolson93
Tolson93
Northern MN
How much would those repairs run at a shop?
RonJon '06
Southern Minnesota
I just had my heads done.....
Valve seals- $45
6.1L Valve springs- $145
Labor- $180
Also, $90 to have the heads resurfaced but it looks like you just had that done. I dropped my heads off at the shop so your labor cost would probably be higher if you leave the truck.
I would probably fix the rear main seal first if that's what is leaking in the pic, then you'll know exactly how much oil you might be burning.
Tolson93
Tolson93
Northern MN
Yeah I'm just not sure what exactly it is couldn't it be also gasket on oil pan leaking maybe ?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Maybe pressure clean or at least brake cleaner blast the oily area to see where the leak is.
NYCruiser
Yonkers, NY
If 4 quarts of oil leaked out you would notice. I say top it off and monitor it if it seems to run ok. Maybe it wasn't topped off last change as mentioned. When was the last time u checked it?
Tolson93
Tolson93
Northern MN
It's been awhile since I checked and I'm right at the 3000 mile mark due for another oil change.
Tolson93
Tolson93
Northern MN
I am it seems so easy
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I **** you not, the hardest part is busting the drain bolt and filter loose because the grease monkeys put them on too hard.
All ya need is a filter wrench and a crescent wrench. That's it.
Tolson93
Tolson93
Northern MN
Yeah I saw that when I was under there.. Should I change it since I just added 4 quarts ?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Uh, yeah. Doesn't matter if you added oil, it needs to be changed when it needs to be changed. Otherwise that's a good way to make sludge.
Tolson93
Tolson93
Northern MN
Yeah should I maybe try and switch to synthetic? Been using semi synthetic recently
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Use straight dino oil. You might have found a leak by using the semi-synthetic since it like to slip past the leaks that are there.
Tolson93
Tolson93
Northern MN
Okay. 5w 30 fine? Or you think any other weight to use?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
The Hemis use either 5W20 or 5W30....I'm thinking the 03-06 uses 5W30. Either way, it'll say on your fill cap. Use whatever is spec'd for it.
Granted, one would think I'd abide by my own advice but I don't. :rolleyes:
*edit*
Wooo 8400!!
Tolson93
Tolson93
Northern MN
Yeah will do. Now I just need to fix my sled back up so I have room to pull my truck in the garage to work on that haha. I'm a procrastinator.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Just use the driveway? :confused:
Must be cold up there still. 80s down here. :D
Tolson93
Tolson93
Northern MN
Were finally warming up to the 50s feels amazing to me , I don't care for 80 degree weather that much too warm ;)
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
haha at least I don't have salt. :p
Either way, get it done. lol
No members online now.
geneseedennis
