Need Immediate Help
Tolson93
Tolson93
Northern MN
Yeah my poor truck is rusting out :( damn salt haha. Yeah I def will soon!
Tolson93
Tolson93
Northern MN
Well I had my work lift up my truck and look for a leak but they didn't find anything where it'd leak out 4 quarts of oil and there was oil inside my muffler.. So I must be burning it then... Best options now?
MyOhFive
HEMI
Find a low mileage one to swap with or rebuild yours.. There's no 'good' option here. Sorry man
Tolson93
Tolson93
Northern MN
Really gonna need a rebuild? Ugh I owe 6500$ and no way I can afford a used engine . Stupid vehicles
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Pull spark plugs and see what you find. You may have a one bad cylinder or more. Compression check will tell you more. Good luck.
Tolson93
Tolson93
Northern MN
Thank you. If a cylinder is bad or more... Better to fix that or just drop a used engine in?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Depends on your mechanical knowledge to be honest.
If you're decent, you and a couple buddies could probably drop one in in a weekend.
Tolson93
Tolson93
Northern MN
Yeah well don't see that happening haha
Redtruck-VA
Virginia
You have to evaluate your engine to determine the extent of the problem. If you have good mechanical abilities it is possible to repair a motor to a certain extent. If you are not mechanical then drop in a known good engine is next. Next you are buying a rebuilt engine and having it installed by a shop which can get out of hand quickly unfortunately. Need to have a trusted shop when going this route.
Tolson93
Tolson93
Northern MN
We have a good mechanic in the family who might be able to help with this. It just seems crazy to need a rebuilt or different engine
ST-8
If your loosing that much oil it doesn't seem crazy to me. How long have you owned the truck? Miles you put on it? Do you normally check your fluids?
Tolson93
Tolson93
Northern MN
Haven't owned it a year yet... I haven't even put 10,000 miles on it yet.. It's at 154,500 miles..
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Compression and leak down test.
Do it right meow!
Tolson93
Tolson93
Northern MN
Gonna have to yeah. That stuff inexpensive for those tests?
ST-8
Unless you bought it from someone you trust you have no idea how the maitence has been kept up with it an if it's been abused or not, 10+ yr old truck with 150,000+ miles can take a toll on a engine
Tolson93
Tolson93
Northern MN
I'm guessing it was abused. So burning oil could be rings or valves? Anything else that could be the problem? Someone mentioned PVC valve ?
MyOhFive
HEMI
You won't be losing that much oil through your PVC. If the valve was never changed and stuck closed it may be contributing to your problem, but that's lack of maintenance and sort of a moot point by now.
A compression and leak down tests are both cheaper than throwing rings at an engine that needed valve stem seals. Compression test you can do yourself very easily. Invest in a compression tester.
The best we can offer online here is speculation, you need to start eliminating possible causes. If the problem is in you're heads then you can keep your motor and do the tear down yourself in frame. If its rings, personally if be looking for a new engine. If you aren't mechanically inclined, or this is getting over your head, just bite the bullet and at least have a shop tell you what's wrong.
Tolson93
Tolson93
Northern MN
Better to be checking oil when engine is warm or cold?
Statcher1
Kentucky
I check mine on a warm engine that has set for about 15mins to let the oil drain back down and settle.
ST-8
Yea after it's been running is the way to do it
joshhhh
