Need some help with LED light strip
sugarray
2015 2500 Mega Cab, Laramie, 4.10
So, I'm going to put a 300 LED RGBW strip on the underside of the rails of my truck bed. I have purchased several items to hopefully make it a smoother install, but have some questions.
1) Can I wire my lighted switch to stay on all the time without a problem? I like the lighted switch so I can see it at night. I got the switch from Radio Shack. It is the Lighted Rocker Switch 275-0731, with a small, red bulb on the on side.
2) Where can I pull power from? I am going to wire the controller (change color) as well and want to have power all the time. I would like to end the strip on either side of the tailgate, driver preferable, with my switch on that side. I have no idea where to look for power there though.
3) Will the strip come on with the switch or will I have to use the remote each time? I may have to get a white strip so it will come on with the switch.
Thank you for all the help!!
Raymond
R/T_Fire
Pleasant Grove
Why not tap into the cargo lamp power wire that way you don't have to add a switch to the dash ?
S
sugarray
I want to be able to turn on and off at the bed, not the cab or key fob (which is time limited)
