Netaudio alpine LOC
Cmacks88
Perdido, AL
Does anyone have any experience with this LOC from Netaudio? Only looking to add an amp for my 2 10’s under the rear seat. 9574e48f899c86cadc92b1449417fccc.jpg
TomT
SoCal/OC
Haven’t used it but Net Audio is legit and I would trust them.
Cmacks88
Cmacks88
Perdido, AL
Yea, I did a little searching after I found that and seen a lot of people using their products. That was the first time I had heard of them. Couldn’t find any posts about that particular LOC though.
TomT
SoCal/OC
I normally recommend the Pac Audio AmpPRO but that was before this existed. I love my Net Audio sub enclosure.
Cmacks88
Cmacks88
Perdido, AL
If I had the money to burn, I would definitely go that route because more than likely I’ll add more down the road and this wouldn’t be enough to do it
TomT
SoCal/OC
Yeah, if you're doing a full system the Pac unit is the best option out there if you have the Alpine. Definitely a big jump in price though.
adamlmathews
Colorado
I used a PAC Lp7-2r for my sub box under the seat and had no problems ..... make sure you ground it. It says not to but it will not work unless you ground it.
Good luck
Cmacks88
Cmacks88
Perdido, AL
Good luck
Thanks for the info. I’ll be sure to ground it
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
What does this thing do? Is it pretty mich the same as this?
kkreit01
Olathe, KS
That's way overpriced. That looks to be a $24.95 PAC 2-ch LOC, with a plastic connector (which they are charging $40 for) to make it plug-n-play. At that price, the active AudioControl LC2i would be much better.
