New 5.7 hemi engine questions
croaker567
Ok so I got a short block 5.7 to put back in my dodge ram. Got the heads worked and replaced all valve seats. So I cranked it up and it smoked like a freight train. Determined it.was water in exhaust and eventually cleared up. It has a tapping noise. Could possibly be a lifter or something. But I don't know what it is. Should I have primed something? What should I do?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
How long did you run it? Did you pull the ASD relay and let it crank a few times to pump up the lifters or did you soak them in oil while they were out bore initial start up? What oil are you using? Sounds like a fresh build so you need to run oil with an additive. Did you assemble the motor or did it come assembled? If a pushrod was off it would run like a pro dragster. Any CEL's?
C
croaker567
What is the asd relay? And yeah I got the bottom end and assembled the rest. Haven't ran it too long. What additive do I need to use and what is a cel?
C
croaker567
So I went and rented something to push oil. I pushed 5 quarts of oil through the oil sending unit and then cranked it up and its still tapping
Burla
2010 Hemi Reg Cab 4x4
Welcome to Hemi's, lol. Check Engine Lights, also could means run the codes.
Break in oils have a lot of zinc that helps smooth the sharp edges. Don't use synthetic until after a short run with a break in oil.
C
croaker567
What should I use for break in oil? I used just regular 5 20. Next time I crank it I'll take a vid. But my oil pressure sensor says I have no oil pressure. But when its off it'll pump oil through the hole like crazy. I'm crazy stumped and cant figure this one out. I thiught it might have been the "Hemi tap" but I'm not thinking so anymore
Burla
Regular Conventional oil is just fine, if you want it to break in faster use a break in additive, IMO not necessary.
C
croaker567
Could my oil pressure switch not working make the oil not flow?
Burla
Generally your sending unit not working would force your computer to shut down your engine, so I doubt it. However, your truck is a lot older so maybe. That would show up in a code for sure though.
Did you run codes yet?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I would put a mechanical oil pressure gauge on the engine to check for oil pressure.
C
croaker567
Ok I will try to see about getting one tomorrow. Its weird how the pump will pump to the oil pressure switch but its not getting anywhere else
RonJon '06
Southern Minnesota
I was wondering if you replaced the oil pump. Could it be the pressure relief valve?
Redtruck-VA
Virginia
You better hope oil is getting everywhere and the sensor is just not working. A engine running without oil will last about 30 seconds before it starts eating the bearings.
C
croaker567
No I didn't change it and is there anyway to tell if thats the problem when I get it open?
C
croaker567
Yeah... I hope so. The thing that stumps me is when I have the oil pressure sensor out it'll pump oil out of that hole pretty good. Could there be like a blockage or something?
C
croaker567
Also it only taps on one side that I can tell
Redtruck-VA
Virginia
Is this a used short block or a fresh rebuild? Typically a fresh rebuild will have a new oil pump installed with the other new parts. You said oil comes out of the sensor hole so I am thinking you have oil pressure but the sensor is dead. A mechanical guage will give that answer. Once you determine if there is oil pressure you can identify the tapping noise. With the valve covers off, rotate the engine by hand and observe each valve cycle up and down as it should. It is easy to have a push rod out of place when you installed the heads. good luck.
