New Rebel - Payload Question
OKGN_RAM
Okanagan
I looked on the door sticker for my 2024 Rebel (Hemi eTorque) and it states: "The combined weight of occupants and cargo should never exceed 612 kg / 1350 lbs"
The RAM website says the maximum payload is 2300 lbs. Can someone help me understand the door sticker numbers?
Many thanks!
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
The 2300 lb number is the best case. In other words, for the lightest truck you could get from the factory. Such as a Tradesman 2WD quad cab with no added options. It's marketing only, and should be ignored for the most part.
Options add weight. Higher trim levels come with more standard equipment. Rebels come with heavier tires and off-road suspension components which may add more weight as well. The payload rating on your door sticker is for your specific truck. Your actual max payload is the number listed on that sticker. 1350 lbs.
Edit: Looks like you beat me to it @chopperman1 :D
