It appears to be the case that there is only the outboard nut (the end away from the Pitman arm) that is the focus of attention. If both nuts were welded to the sleeve, it would render the drag link junk.
My Mopar app showed my 2017 2500 as part of the recall. While I realize that not all >2500 Ram vehicles are affected, I would like to know the proper torque value for the affected nut. I am guessing that FCA is not being more specific because they do not want just anybody to attempt a fix at home, but the correct torque values would be helpful.I just check my Mopar app and it usually lets me know about recalls. Good app.
So if it's not loose weld it???? So it can never be adjusted if need be???
So a few years later you're in the shop and the mechanic says good news, you just need an alignment, bad news I need to replace the drag link assembly because some ******* welded it....
Statement: Steering Linkage February 5, 2019, Auburn Hills, Mich. - FCA US LLC is recalling an estimated 573,876 heavy-duty trucks in the U.S. to address a potential steering-linkage issue. An FCA US investigation discovered a specific steering-linkage configuration on certain vehicles may separate over time. If this were to occur, the driver may experience steering loss. The Company is aware of one potentially related injury and eight potentially related accidents. The recall population is limited to model-year 2013-2017 Ram 3500 pickups and model-year 2014-2017 Ram 2500 pickups and 3500 chassis cabs. Customers will be advised when they may schedule service. Those with questions or concerns may use online search engines such as the one at recalls.mopar.com to determine if their vehicles are in the recall population. Alternately, they may contact their dealers or call the FCA US Recall Information Center at (800) 853- 1403. Additional vehicles will be subject to recall in Canada (est. 62,734), Mexico (est. 17,682) and certain markets outside the NAFTA region (est. 5,837).
