New running boards
greydodge
California
cummins 5.9
Have 06 2500 standard cab looking for running boards that will go beyond the cab so I can use it to get to the tool box don’t need to spend a bunch it’s just a work truck with 390,000 miles
Any ideas? Thanks
G
greydodge
California
cummins 5.9
I’ll check them out
Thanks
Do they bolt on the truck frame or the body frame?
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
So my question is would a pair of OEM power boards from '19 New body style fit/work on the Classic 4th Gen body?
hunterdan
SE PA
2019 classic
No, the cab mounts are different, unless you find a set off a 19+ 2500/3500.
hunterdan
SE PA
2019 classic
So just to make it clear- a set off of a 5th Gen 2500/3500 will fit a 4th Gen 1500?
Yes, because the "5th" gen 2500/3500 aren't a true 5th gen. They are still using the 4th gen cab and bed.
