New Windshield, Rain Sensing Wipers Messed Up
The Q
South Texas RGV
2014 Sport R/T
Caught a rock on my two month old R/T's windshield. Chip spread before I could get it fixed, so I had the windshield replaced. Now after replacing the windshield if I have the wipers set to auto rain sensing they make a single sweep at startup. It didn't do that before so SafeLite is going to replace the windshield because they think the windshield is defective. Just wondering if anyone else had a similar experience and if they had a diffrent resolution?
mjd91
San Marcos, TX
The windshields are different if they have the auto wipers. Maybe the wrong one got installed.
The Q
The Q
South Texas RGV
2014 Sport R/T
The windshield is for rain sensor. The sensor is installed and hooked up and kind of works as it should, just not like it did prior to the new windshield. Prior to the new windshield if the wipers were set to auto (rain sensing) the only time they moved was when moisture hit the windshield and the sensitivity was near perfect. Now, with the wipers set to auto, every time I start the truck they swipe the windshield once. Today we've been having a little tropical rain and the wipers aren't as sensative to moisture as they were new.
The Q
The Q
South Texas RGV
2014 Sport R/T
Humidity Sensor???
Had a windshield replaced in my NEW 2014 Ram Sport R/T the other day after catching a rock and getting one heck of a crack in the glass. I had a rain sensor windshield installed, but my rain sensor doesn't work like it did before. The glass installed is an OEM glass. When I look at the Safelite web site I see there are a couple of options, one includes rain sensor and humidity sensor. After looking at Ram web site info it seems to me that all 2014 Ram 1500s have a humidity sensor. Can anyone verify this??? I'm thinking this may be part of the rain sensor issue. Again, the glass installed only has the rain sensor, just not the humidity sensor.
The Q
The Q
South Texas RGV
2014 Sport R/T
Thanks for the reply. Neither the window sticker or build sheet show it. Ram's website says all 2014 1500s have it, I just don't know what it looks like or where it is located. I just want to get the correct windshield.
Griff2014Laramie
North Carolina
Rain Sensing Wipers Possible Fix
I just started on this forum after I had my windshield replaced by Safe Lite auto glass. Windshield is the correct OEM and rain sensing. However, like many of you my wipers would swipe on start up. After multiple inspections of the glass and consulting friends at Chrysler I ended up on the phone with Safe Lite. Extremely helpful! I talked to the executive team and we came to a possible conclusion that there is a gel pad that sticks everything back to the windshield that if not in the exactly correct position, or with a wrinkle or any imperfection could cause the rain sensor to "see" moisture if you will. Not sure if this is the fix. I will be inspecting the windshield again and Safe Lite will be returning to take their time and replace the gel pad. If this fixes my issue I will pass it on.
The Q
The Q
South Texas RGV
2014 Sport R/T
Safelite ended up installing a second windshield in mine due to the rain sending wipers making a single pass at start up. Happy to report everything has been fine since then! Good luck with your repair.
kramzerreitug
Just had windshield replaced 2015 Ram Longhorn. Now same problem with rain sensing wipers. Everytime I start the truck they give the windshield a swipe. Safelite says that is how they work... We all know that is not true. First they brought wrong windshield. Then they ordered OEM windshield. Will call local Dodge dealer for recalibration? Does that make sense to anyone?
The War Wagon
da' 'BURGH
318 Magnum
I'm so old, I remember when you had to turn the knob on the DASH, by HAND. And it had two settings: "ON," and, "OFF." oji.gif
The Q
The Q
South Texas RGV
2014 Sport R/T
Tell Safelite to get another windshield! That's how they fixed mine. The tech said that they get defective / incorrectly installed rain sensors, even on the OEM glass. It took two OEM windshields to fix my problem.
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
We got a new windshield in July. Wife got hit by a rock two weeks ago. Smashed the windshield.
She wet to the glass shop and twitched out. Lol.
He was going to lower the price for her. Wife lost her cool. Got it free. Lol.
Next time you smash your windshield, call me. I'll send in my wife. Lol
Grant211
I’ve noticed the same thing after my windshield got replaced
with the rain sensor turned on...my truck will perform single swipe
Calling safelite to see what they can do.
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Haha!! Truth..
ctdodge
Bristol, CT
2017 Laramie 1500
If you were even OLDER, you'd remember having to feed your "car" oats and clean up the piles it left behind!
Grant211
Fwiw there are apparently 4 different windshields on the truck. I think this is the problem I’m having. They installed the wrong windshield and this is why I am having the problem
Tizzy
SW WI
I’ve got the same problem with the single wipe at start up and random phantom wipes (no moisture) with a factory windshield (never been replaced). It’s a Laramie with factory rain sensing option; not something I added.
Outside of changing the windshield, is there any other way to fix it?
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Remember my '48 Buick had a big knob at the center of the split windshield that operated the wiper by hand.
No oats or fly infested piles, though.
2002dodgenvhelp
