hello I am new to the forum and while I keep browsing for a problem similar to mine I thought I would post this here in hopes that someone may know what is going on.
i have a 95 ram 1500 3.9L most of the time it starts up just fine but randomly it will decide not to start at all. There is no crank or sound like it attempts to start absolutely nothing other than the dash lights and radio come on. I have replaced the starter and battery cables and it started and ran reliably for a while but I am now plagued with the same problem again. the battery tests at normal voltage levels and It does not start if i try jumping it with a machine. I do remember checking the codes by counting the flashes and i recall it has code 34 there may be others so i will run down and check them in a minute. any help is appreciated as this is my work truck and i need to find a permanent solution.
