Hemi395
- Mar 18, 2013
- 9,506
- 17,678
- Location
- Cape Cod MA
- 2013
- 5.7 Hemi
Truck is a 2013 1500 5.7 65RFE.
Figured I'd put this out here in case anyone has any ideas. I have a rattle/pump sounding noise at around 2200 RPM while under load. I've heard it in 1st 2nd 3rd and 4th gears and only while under load. It's only at that specific RPM.
Heres what doesn't make the noise:
-P or N reved to 2200
-Power braking it in D or R.
-Using a scantool it doesnt seem matter what line pressure is or TCC lockup stste
-If i floor it and it goes above 2200 RPM
-If it's under load UNDER 2200 RPM
-If I hold speed in any gear to equal 2200 RPM and it's not under load like on a flat road
-It is nor speed dependant, only 2200 RPM engine speed under load
I first thought something pulley driven but I pulled the belt off and everything is smooth and quiet. Also everything pulley driven but the AC compressor is newer Mopar parts
The truck drives and shifts perfectly and has 0 codes stored. I had my wife listen from the passengers seat and she said it sounds like it's coming from the front passengers side. I switched so she was driving and I was in the passengers seat and I can confirm that's where it sounds like it's coming from.
Normally something like this I would turn the volume up and ignore it but it almost sounds like a noisy power steering pump at that RPM. Since I have electric power steering the only fluid pump is on the transmission.
AND we're towing the camper to Virginia in April so I need to know if anything is about to $h it the bed. I've been talking to back and forth with @Burla @Brandon-w about this and we're stumped.
Here's a video of it, at about the 4ish second mark you can hear it.
youtube.com
Thanks in advance!
Noise starting at 5 seconds
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Thanks in advance!
