Non-8.4" Radio Swap...Sony XAV9500ES with Dual Zone ATC
Dissent
East Tennessee
I thought I'd give you all some feedback about my experiment, my non-8.4" radio swap.
I began with a 2013 Ram 1500 Tradesman with the basic radio and Single Zone Manual Temperature Control (MTC). I was intent on converting to Dual Zone Automatic Temperature Control (ATC) and incorporating Prolific Audio's "Ram Truck 2013-2018 OEM 8.4″ Screen Prolific Audio Sony XAV9500ES Full plug and play kit" without any OEM 8.4" radio involvement as I don't have one and preferred the larger 10" screen and aftermarket support the Sony provides.
Here's a link to the Prolific Audio site: https://prolificaudio.com/product/r...-audio-sony-xav9500es-full-plug-and-play-kit/
Here's a link to the Prolific Audio installation video on YouTube: https://youtu.be/NdO6IhC2J6o
I bought a Dual Zone ATC kit from Mike at M2 Mods (https://www.m2mods4ram.com/) which included a custom wiring harness, an 8.4 Dual Zone ATC bezel, an OEM A/C computer and a 7-speed Fan Resistor along with detailed directions. I installed the M2 Mods kit without any issues. I then loaded up AlfaOBD to tell it I was changing from MTC to Dual Zone ATC and everything just worked without any additional configuration. Such an easy conversion, wish I had done that when I first picked up this truck!
I was really impressed with the 3D printed and custom cut ABS pieces in the Prolific kit. Installation was quick, about 40 minutes total following along with the YouTube installation video. Note, the video included CANBUS wiring which I did not require...that part was a little confusing as I wasn't sure how the system could communicate with the truck. When I added the Prolific Audio harness and Sony radio, it just worked.
I was shocked how easy it was. The Mestrao unit included in the Prolific kit plugs into the OEM harness and I plugged 2x wires from it into the Sony (data and phono). No CANBUS interface was required as the install video showed. I’ve no idea actually how it’s pulling data, must be through the OEM radio plug? I'm using the RCA low level outputs to a pair of AudioControl amps.
I didn’t have to do anything with the speed sensors, parking break, CANBUS interface (surprising), or reverse switch. I don’t have a camera connected but the radio tries to activate it when I go into Reverse, just says “no signal” for now. Very slick.
All the A/C controls appear when I touch the dash controls and I can change all the buttons, fan speed, manipulate the mixing doors. There’s actually a “Single” button on the screen that combines my Driver and Passenger Temp Controls and controls them as one. Very nice.
The only thing that doesn’t work is my TPMS which is par for the course with the way the 2013 collects and feeds the info to the OEM computer. I expect 2014-on would work fine.
I'm so very impressed with the way the 10" display fits the dash, it's such a massive improvement over the 1.5" gap the XAV series radios normally exhibit. I'm very glad I went with the ES over the other model, there's some more bells and whistles I'm glad to have in my toolbox. This the 3rd Sony XAV series stereo I have (wife's car and son's car have the others) and I'm always impressed with Sony's product line.
Bottom line is if anyone asks, this configuration worked flawlessly and note that I've never had an 8.4" radio, just the basic radio.
Here's some pics. The first couple are the unit head on and from the driver's perspective. The third is the side, looking at the form fitting adapter behind the Sony display. The last pic is same side, just from the driver's knee area to show the fit on the bottom.
FYI the hole in the dash is for my missing 8-speed shifter, it's stashed somewhere safe...where I can't find it. I'm still using the 6-speed with the column shifter. Just waiting for cool weather again to do the 8-speed swap!
Dave
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Looks good Dave!
That's a very polished install from Prolific and good option for those that don't want to go with a factory 18-22 4c 8.4 AA/CP radio.
MattCham
Saskatchewan
3.6L V6
Dave
Clean install, how is the wiring in the back? I've installed the Stinger Heigh10 for people and it was a bunch of wires.
Johnnguyen6596
