O2 sensors
Scarlson60
Cape Coral
2014 Ram 1500 Hemi bank 2 number 1 sensor changed twice and code keels coming back
Daw14
South Florida
Use OEM sensors on any vehicle for chance of best results , aftermarket may not play well .
Inspect what harness you can .
S
Scarlson60
Cape Coral
The Bank 2 plug is on top of the transmission it’s hard to check the pins but I like your thinking.
S
Scarlson60
Cape Coral
Funny I started having this problem after I had the MDF solenoid changed out.
62Blazer
Midwest
The scanner or code does not say "the sensor needs to be changed", only that there is some sort of unusual reading coming from the circuit that goes to that sensor. From my personal experience if you see a code that states an O2 sensor it's only an issue with the actual sensor half of the time. Quite common to see wires frayed or broke, or the connector corroded or bad........or of course the sensor could be reading perfectly correctly but the engine is not running correctly. Still remember my first experience where a buddy literally replaced the same O2 sensor 4 times and the code still came back. When I took a look it took about 30 seconds to find the wiring melted against the exhaust. 5 minutes later and a little wiring work it was fixed.
turkeybird56
Central Texas
OP wateva U do OEM only on O2 sensors and check pins and wiring also.
