Odd problem all of a sudden
Bigdodgeram828
North Carolina
4.7L
Here in the past couple days while driving my truck has started this very annoying jumping up in rpm problem. Everything is fine when started up but as soon as I start down the road driving at 55-60 (even less or more) my truck will rev up to 2000rpm and then back down to 1500 about every 4-5min. It does not do it at idle. No check engine light on either.
The only thing i've had done lately is I had my A/C fixed and catalytic convertor replaced. Any ideas, kinda clueless right now since it's not throwing a code.
jhemi
wisconsin
could be a/c pump kicking in and out, just a thought
Bigdodgeram828
Bigdodgeram828
North Carolina
4.7L
I haven't even tried turning the A/C off yet while driving, I've been enjoying it to much in the 90-100 degrees lol
dth418
Pittsburgh PA
you will typically see a slight rpm jump when your a/c compressor kicks on but it shouldnt be that much. I would definitly try turnign it off while driving for a bit and see if that helps out
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
What did they do to fix your A/C? The compressor could be dragging causing the spike in RPMs then it falls back to normal once it spins.
Bigdodgeram828
Bigdodgeram828
North Carolina
4.7L
All the guy said was there was a small leak he fixed it and filled it back up with freon. Said everything else looked good.
