Odd shifting?
Jakal
Yuma
I have a new 2020 limited 4x4 off-road edition with 5.7l hemi 1500 miles on it
when driving at a constant 35mph (around 1200rpm) it will seem to hunt for a different gear intermittently and I can feel it shift. The rpms do not seem to change
just seems odd
the 2017 big horn 4x4 with the v6 I traded in never did this as it was smooth as silk shifting at all times
I had 27000 miles on it
thanks
jack
yuma. AZ
RandomRam
On the Oregon Trail
Sounds more like MDS engaging and disengaging. Try setting the gear limit to 8 using the buttons on the steering wheel. If that smooths it out there you go.
J
Jakal
Yuma
First trip today around 50 miles of in town and interstate
Totally all miles using 8 setting
not one instance of issue
going to try a couple more trips to make sure this is it
if so is there a fix to this or do you just have to run in setting 8
If no fix available is it hurting to leave it in normal (mds) mode
RVGuy
Alberta, Canada
I think it's normal operation. If I remember correctly the MDS will activate and deactivate intermittently to prevent the 4 cylinders that deactivate from cooling down and creating issues.
In terms of being able to feel it, it seems like some trucks/people are more sensitive to the MDS but I can't see it hurting anything by letting it do it's thing. I personally turn mine off but that's more because I don't like the feeling/sound of it kicking on and off constantly.
J
Jakal
Yuma
Does the mds function at all speeds
I thought it was just 60mph and above
buddy guy
alberta
All speeds. I can hear it motorboating as I drive through my 20 mph neighborhood.
Sent from my SM-N960W using Tapatalk
RVGuy
Alberta, Canada
Yup, all speeds. If I leave it on I can hear it running at 30km/h and it'll even stay on while accelerating around corners if I'm light on the throttle.
RandomRam
On the Oregon Trail
Glad the gear limi trick worked. I have a 2500 but my 6.4 does the exact same thing. I leave MDS on while driving on the freeway but disable it in town or in the forest. The low speed activation is a bit of a nuisance but I do notice better fuel mileage leaving it on when driving highway speeds.
J
Jakal
Yuma
Going to make another drive today
I will post on how it goes
thanks to everyone for the info
jack
J
Jakal
Yuma
20 mile round trip in city today
First half in 8 option with no issues
Second half in normal drive and no issues either
will try again tomorrow to see what happens
J
Jakal
Yuma
Final report from today’s 50 mile round trip
Felt the truck have the issue twice while in mds normal mode when running around 35mph. Put the truck in 8 mode to bypass mds and never felt it again. Thanks again to ALL who helped me out with the great info and advise
jack
