Oem led tail light wiring harness
30stones
Duncansville Pa
Hey guys been searching the internet and can't find anything. Does anyone know where I can find the oem wiring harness for the back of the tail lights. I just recently bought a pair and they didn't come with the harness. I'm not looking for the retrofit one. I need the oem one for the back of the tail lights.
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
Wow... out of curiosity, I dredged rockauto, and nothing there, either.
Outside of sacrificing a virgin to the dealership, or scrounging junkyards... I wish you luck, man :/
korby05
Delta, PA
5.9 Magnum
Have you tried Jeremy retroshop. He may be able to guide you in the right direction.
Sent from my SM-G950U using Tapatalk
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Yeah the wire harness that is normally attached to the OEM LED tails is considered part of the unit. No separate part number. If you pick up a set of tail without the wire harness you are out of luck unless you find a wrecked truck to pull from.
30stones
30stones
Duncansville Pa
Just a question, what happened to the OEM ones that came in your truck?
I have the non led tail lights so in order to use the conversion harness retroshop sells I need the OEM harness for the led tail lights. I bought then off a guy that bought recon tail lights and unfortunately recon tail lights sell them without the harness so you have to use your existing harness off the original tail lights.
30stones
30stones
Duncansville Pa
That sucks. Looks like a wiring harness will be harder to find than I thought. I picked them up for super cheap so I figured it would be worth sourcing the harness
Jimmy07
I think @wayned87 might be able to help you...hopefully.
Jimmy07
I found those in a thread from 2 years ago. It linked to his eBay listing, but it ended. You might try PMing him.
wayned87
Clinton, UT
2015 Ram 2500
Just thought I would let y'all know that I am back up and making these again. Been a long move across the country with the help of uncle sam. If anyone is interested just message me on here, Instagram, or Facebook. green_angel_tuning
Thanks
Cesar592
3.6 pentastar
Cuánto es wiring harness
northvibe
Minnesota
Just to verify, I have a ram 1500 big horn, looking to add the oem led tails. All I need is that harness above to adapt and alfaodb to enable led, correct? I should not need that harness with a resistor built in.
chrisbh17
Classic (4th gen) or DT (5th gen)?
