Oil Change at Dealership?
Hookie
Eastern Ky
How much should a oil change cost at the Dealership for a 2015 Ram 5.7 with full synthetic oil?
trip1027
I don't know but it is way cheaper if ou do a contract. I never do full synthetic in my truck
Sent from my SM-N920V using Tapatalk
16laramie4wd
My dealer had 4 semi sythetic and tire rotations for 120
trip1027
cost extra 194k miles laterstill no full synthetic
trip1027
contract stating u buy 4 or 6 or 10 oil changes at one time.... when your oil change is due you co.e in to get it ez pz
kevperro
Pentastar 3.6L
Never had a full synthetic change done by anyone other than me. The difference in the cost of oil is minimal at Walmart. I have a feeling dealers, oil change places and everywhere else treat it as a premium service and charge accordingly.
I change my truck at home and it only takes 15-minutes. It is actually easier than taking it to the dealer except in foul weather. Wait for good weather.
Either way... 5 Quarts of synthetic at Walmart is $17-$25 for your standard fare synthetic. You may want to stick with the Penzoil flavor that is MS-6395 if under warranty. "Standard" discounted motor oil that is still MS-6395 rated is around $12-$18 so about $5 difference per oil change.
I think if you stick with anything that is MS-6395 rated you cannot go wrong. I'd ignore the synthetic vs. dino oil thing. As long as you stick with oil that meets MS-6395 and is of the appropriate viscosity your engine won't know the difference. (flame suit on).
mtofell
I got a 6-pack of changes for my 6.4, full synthetic for about $65 each. I doubt I can even buy the materials for that. Certainly, not for enough less to take my time doing it. I usually need to get to the dealer a couple times of year anyway for recalls and updates.
If I recall, just buying one change is almost twice that for my truck.
trip1027
It does cost alittle more but you can go alot longer between oci using synthetic oil.
like what? I do oil changes every 6k to 7500 miles
Hookie
Hookie
Eastern Ky
Thanks for the info guys. The only reason the dealer changes it is due to a disability.
I think i'll ask about a contract next time i go in.
BossHogg
Oakland Township, Michigan
6.7L Cummins
Check your dealer's website, also dealers in your area, look for coupons in the service section of their website. I'll find a dealer that is offering a four oil change special for cheap (the last contract was $67 for four oil changes). Be aware that the oil change contract also has a time limitation, four oil changes in two years, after two years the contract expires. Also, the contract is a Mopar contract and is valid at any Chrysler dealer.
baum
savage, mn
2015 Laramie
^^ what he said about the time frame. I do a 4 pack for about 79 or so of regular oil. I just in every 6 months which is about 5k in miles for me. In my case the oil life gauge on the dash is only about half down. that way i use all the oil changes up in 2 years.
adrianp89
Tampa Bay, FL
I went nearly 10k on Mobile 1 high mileage full syn. Sent my results to Blackstone and the results were outstanding. +1 for doing it your self. 30 minutes tops. Probably 15 minutes if no 4x4.
Skerj
FL, from MI
I'm doing my first two (or 4? Some are free with the truck when bought new) through the stealership. After that I'll be doing my own. But if you have to take it somewhere, the dealership would probably be better if something was to come up warranty wise, as opposed to the quik e change type shops.
CrispyBacon
There is definitely a difference on cold Canadian mornings.
Frisk
Edmonton, Alberta Canada
For me the biggest benefit for going with synthetic oil is the cold starts in the winter.....The engine cranks over way easier with synthetic in it at -25C. There are lots of videos on the internet of people showing how conventional oil pours at cold temps compared to synthetic.
