fitteenhundred
Are the 20-820's all made in Mexico?
Ok sorry if I’m dumb. Fe2? I found the endurance that fits. The part number is fe10060. I don’t see anything that says fe2 or XG2 like the other comment said.only at walmart fram endurance fe2, or the amsoil ea for hemi.
Then my Ford would take the same filter as my Ram. Ooh...I hadn't ever thought of this.If getting decent 22mmX 1.5 filters is getting hard,i wonder if we all shouldn't be swapping back to the older 3/4-16 filter n!pple and using the old style 3/4-16 filters.
I've been kicking that one around for a bit on my cars,as they have lots of room to run an old school style 30-8 filter,which is alot bigger then the 20-820 filter.
MOPAR 04104511AB Oil Filter Adapter for 03-07 5.7L
MOPAR 04104511AB Oil Filter Adapter for 03-07 5.7Lhighhorseperformance.com
2001-2008 Mopar Oil Filter Adapter Connector 4104511AB | Mopar eStore
2001-2008 Mopar Oil Filter Adapter Connector 4104511ABstore.mopar.com
04104511ab - Short Block | Mopar Parts Canada
Oil Filter Adapter - 4104511. Genuine Mopar® Parts & Accessories. Manufacturer Warranty. From the Dealership to your Door.www.moparpartscanada.ca
It adds about 1.5 more quarts to an oil change,it takes about 8.5 quarts to bring it to the full mark on the dipstickHow many quarts does your large dual filter system take? Just curious.
jw is correct, the fe2 is the larger filter it should fit and it was more beneficial especially because of the less holes. The two filters with 8 full size holes is the 20-820 and the fram ultra. Which is the decision, which is better full synthetic media or two extra holes, would answer the question between what is the second best filter fe2/amsoil ea versus fram ultra. Fram having more holes and the others having better media, which is why I would buy one filter and test it before staying with the fe2, just make sure it isn't restrictive, it is probably fine but the last time I hung a 6 hole filter my truck got a nice tick. It is what it is, hopefully your truck isn't as finicky as mine, I still have the second peice of junk filter because I bought two. So this I say try it before you go buying a bunch.Ok sorry if I’m dumb. Fe2? I found the endurance that fits. The part number is fe10060. I don’t see anything that says fe2 or XG2 like the other comment said.
I have some running around today,that puts me close to my dealer,so i think i'm going to stop by and see if they have the older filter n!pple in stock,if not,i'll order a couple.Then my Ford would take the same filter as my Ram. Ooh...I hadn't ever thought of this.
Putting this onto 'next parts order' from dealer list. Thanks!
I have a couple of the n!pples on order,as they don't stock them for the older 5.7's,if i wanted the later 22mmX1.5 n!pple they had them in stock.They're about 7 to 10 days outThen my Ford would take the same filter as my Ram. Ooh...I hadn't ever thought of this.
