Fumbling around a bit more on the awful Fleetguard website, they no longer list media type on most filters. Neither do they use their StrataPore tradename anymore. Remember, it was introduced 35+ years ago. It's likely no longer relevant to them since they recently introduced their "NanoNet NN" media.
They've been bashing competitor Donaldson for retaining "30 year old microglass" media and showed micrographs of broken glass shards in used engine oil. NanoNet is plastic media. It is polypropylene string, commonly used in water filters these days. The problem with plastic is it melts ~ 300 degrees F. They're playing with fire, here, as hot running engine oil is not a uniform sump temperature - it picks up a helluva lot of heat at the cylinder heads and upper walls - that is HIGHER THAN the sump oil temp. My sump temp runs ~ 230 degrees F on hot days.
Granted, they still publish media efficiency without identifying the media type. As
@Travis8352 notes, their 90% @ 21 micron particle size is likely not cellulose (paper), but what is it, then? Fram Endurance advertises 99% @ 20 micron particle size. Is Fram using microglass?
Who TF knows anymore!!
