Oil Filter Thread
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Product Defect Alert!!!!!!!!!
Wix xp oil filter I was putting on was wobbling as I spun it on, the Nut portion of the oil filter was not straight Inline with the rest of the oil filter housing. Making it wobble as I spun it on, resulting in one side of the seal meeting the engine block first as I tightened it down. This defect resulted in a bad seal; took it off and replaced it with another new Wix xp oil filter I had and it had the same defect. So, if your running this oil filter or have one you intend to use this is something to be looking for. I always do a visual inspection on all my oil filters before I put them on and this was something I could not see until I was spinning it on.
Stefan N
Sweden
2015 Sport
Part # for the faulty filter?
Stefan N
Sweden
2015 Sport
Thanks, so not concerning RAM owners then? at least not Hemi 5.7 that uses 57060XP right!!?
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
Correct two different part numbers as of today. Last year when I got my new truck they shared the same part number so there may be a few using the old part number. Hopefully know one will a mess under their truck like I did.
I was in a pinch for an oil filter so I went with the tried and true M1-113A EP. Spun on flat and snug. Looking at the Purolator Boss for my new filter selection.
Ramnewbie
Interested to see what you're results are with the boss filter. I've got a couple on the shelf, I thought my engine made more noise at startup with the boss filter. I just quit using them and went to FU or Amsoil filters.
Ramnewbie
Looking at changing the oil in my 03 5.7 235k miles. Want to try RL. Would you suggest a viscosity blend? What would be smart
This is JMO, but if you're the original owner and that motor is all original I wouldn't vary too much from what you've been doing, it looks like whatever you're doing is working. Viscosity wise I'd use a 5/30 but at this point unless you've been running a synthetic before I'd be causious about changing to synthetic now. If and I say if you want to change to synthetic now I'd use a can of Amsoil engine flush first. At this point I'd be more afraid of creating more problems by changeing to redline, you might be better off with M1 high mileage. JMO. I recall that you said you also have an 18 so if you're using the 03 as a test dummy just to see what happens id do the Amsoil engine flush and then redline 5/30. Please keep us posted on what you do and you're results.
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Good point. Yes bought new. Have been using RP synthetic 10-40 for most of its life. Recently tried Amsoil SS 10-40. Small drop in PSI but thermal temp came down. Did notice mild increase in lifter noise when at full op temp. Added a can of Liqui Molly, went a way. I am testing the top tier oils, so can't realy cause a problem. But your point on miles versus switching oils is a caution. Thinking RL viscosity blend. Like 2 Qt 10-40 5 qt 5-20?
Army
For the 5.7 I like redline 5w30, for the 6.4 I like 5w40 redline. I don't see a lot of reason to blend redlines, some guys are chasing moly or zinc levels but the two I just posted are really stout base oils and high additives as well. Some guys in the cold states want what 0w40 redline has to offer in the cold, but find that noiser then 10w40 redline for the summer. Kyle's experience comes to mind, but 5w40 seams to be the best of all worlds for the 6.4. As for the 5.7 they should just rename 5w30 redline as hemi honey, it will smooth out any noise you are having and have no mds issues.
Fitz-0518
Veteran 66-68
Central California
You guys should get paid for your patience and advise. Thanks, makes sense.
grizzstang
Calgary, Alberta Canada
I am creeping up to my next oil change and was looking to try the RP 10-48 but I can't seem to get one here for less than $45.00, yes you read that right, so I might give the Fram Ultra XG10060 a shot as I can get them for $15.99 at my local Canadian Tire. I believe it was in the top three in testing at the beginning of this thread. Anyone here using one and happy with them? I have avoided using Fram and their "orange can of death" most of my life so I am a little concerned.
al1257
