S0CAL
US Marine Veteran
- Feb 3, 2016
- 3,207
- 3,528
- Location
- The Lonestar State
- 2021 Limited Longhorn CTD HO DRW 4x4
- Cummins 6.7L HO
I recently attempted a Fumoto Drain Valve kit for my drain plug. My factory plug works with no leaks BUT in an attempt to install the Fumoto, I realized it was going in cross-threaded. I pulled it out, reinstalled the factory and sure enough, it inserts at an angle. Again no leaks.
My die and tap set only goes to 12mm and I think the diameter of the hole is 14mm. Other than a machine shop, where could I find a 14mm rethread kit? I am coming up short.
Thanks!
Thanks!
