Milburn
'12 Ram 1500 with 3.7 V-6. The oil pressure light would illuminate intermittently, and I was told that the sending unit was going bad. Had the same shop replace oil pressure sending unit and same problem continued, just not as frequently. I've discovered that if I turn truck off and then crank again, the oil pressure light will go out. Sounds like an electrical problem rather than a bad sending unit. Anyone else here had the same problem?
