OK what is this cluster symbol?
Ramsportrocks
east gabip
popped up in Amber after I installed my premium replacement cluster
went away after 2 key cycles
desync0
Ontario, Canada
2019 Classic
DEF fluid low, don't think you have to worry about that on your Hemi lol
If it doesn't come back on I wouldn't worry about it, cluster was probably from a diesel truck.
Ramsportrocks
Ramsportrocks
east gabip
this is correct..so far hasn't come back
tidefan1967
Summerville, South Carolina
You put an Ecodiesel cluster in your HEMI powered RAM? Does it bother you that the tach only goes up to 5K where the HEMI cluster goes to 7K? and having a DEF gauge instead of a volts gauge? I'm surprised that it would work at all.
Ramsportrocks
Ramsportrocks
east gabip
you make a lot of assumption from just a light .. the tach goes to 7K and it has no def gauge.. the light that came on was probably a byproduct of the cluster programming and I would bet it is a standard light in ALL of the 7" clusters..
22hemi13
Tucson AZ
2014 2500 4x4
Huh. I’ve never seen a diesel cluster that didn’t have a def gauge on it. Who knew lol
tidefan1967
Well if
well then it’s definitely not a diesel cluster then and on the other hand just for the sake of conversation now because it’s not important to me one way or the other do you have the HEMI or the ECODIESEL?
