opinions on using engine to brake or brakes to brake
Use Brakes or engine to brake
  • Total voters
    10
Neil E
Morganton, NC 28655
I drive 35 miles to work. I go up a 6% grade on the way to work, but of course, go down it in the afternoon / early evening on the way home. It is about 5 miles long, drop from 2700 ft to 1200 ft of elevation.
I always use the engine to break. I set my cruise at 53, and let the transmission downshift to hold the speed (the speed limit is 55, but when I set the cruise at 55, the RPM's stay at or above 3500 rpms, and the oil runs 90 psi in pressure.
I grew up learning not to use the brakes when going down steep declines, but am I causing damage to the engine running 3400 rpms for 5 miles. Just asking opinions and will try and do a poll.
Tach_tech
5.7L HEMI
That is what I do down steep grades and its not hard on the engine at all. There is no load on the engine going downhill like that and it will actually spend most of the time in decel fuel cut off, so theres little to no load and not using any fuel.
The 8 speed has special programming for this. If you have the cruise on as you say the transmission will downshift to help maintain speed. If cruise is not on and you tap the brakes quickly it will downshift as well. Riding the brakes all the way down is going give them a chance to overheat then warp.
CVX20
Ont,Ca.
2019 Classic Express
Don't totally agree that it doesn't do damage to the motor.I don't like riding the brakes either but the motor is built to put out power not to have the power rammed back into it.Usually the throttle plates will be closed so it can't get air into the cylinders creating a vacum that will try and suck the oil past the rings.Don't be too surprised if it starts using oil.Ask someone who downshifts hard with their standards on a regular basis.
Anyways you're taking something that was built to do one thing and forcing it to endure the exact opposite.
Reactions: U&A
If your oil control rings or valve seals are bad, your going to get oil into the cylinder whether your accelerating or engine braking so the oil consumption is a moot point. If an engine can make the horsepower, it can take it. Only when you shift into the wrong gear and over speed the engine do you risk damage.
If you rely on your brakes too much descending a grade they may not be there to stop you before major front end damage occurs.
U&A
2016 3500 SRW
6.4 HEMI
I use the engine to break all the time. The truck can handle it
Do it
IMO
Sent while firmly grasping my redline lubed RAM [emoji231]
U&A
2016 3500 SRW
6.4 HEMI
Every time i drive it.
And it uses no noticeable amount oil
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
90 psi, as in ninety? Are you sure?
Never actually watched during decel. I can see 5 percent increase but not 30
U&A
2016 3500 SRW
6.4 HEMI
The engine was designed to do it.
So don’t be afraid to do it.
rotwiler
Washington
May hit 90, my oil pressure on acceleration is can hit mid to high 70s, normal cruising at 60+ mid 60s. I have one of those odd higher than average oil pressure Rams though, but zero hemi tick.
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Don't be a wuss. Just kick that baby in "N" and let her roll. It's like getting free gas. Brakes are over-rated.... :)
Tach_tech
5.7L HEMI
Except in neutral your using fuel to keep the engine running. During decel or down a hill you’re in decel fuel cut off which uses no fuel.
However if you wanna gain some free speed at idle, give er.
Neil E
Neil E
Morganton, NC 28655
Yes, once the RPMs hit 3500 they jump up. It seems to be normal, I just don't like the oil pressure that high.
