Out of control wagon
dusterd
2015 power wagon
Hey guys i need help here my 2015 powerwagon has 38000km on it and with my atv in the back of it weighing around 850lbs i cant go over 95km/hr and it starts to sway out of control. Any help is appreciated.
Sent from my SM-G920W8 using Tapatalk
1500ram12
5.9L Cummins
Make sure your front sway bar is connected and check your tire pressure
Sent from my VS985 4G using Tapatalk
D
dusterd
2015 power wagon
Thanks i will pump up tires more to see if that helps. Shes going in tomorrow to dodge they can check the swaybar
1500ram12
5.9L Cummins
I know on the power wagons the front swaybar endlinks are electronically controlled (disconnect/connect) that will give you the feeling on turns no matter how sharp that you are tipping over and will rock side to side. Low tire pressure with a load will give you a swaying feeling.
D
dusterd
2015 power wagon
It does it on smooth highway with no wind it will just start to whip and sway.
Searay245se
BrookPark Ohio
2015 Power Wagon Laramie
When I picked my PW up at the dealer they had put 85 lbs of air in the tires when they should be 60 and 65.50 mile ride home was like driving on ice,truck was all over the place.Check air pressure first and if right take it to the dealer and let them deal with it.
