Overhead cam.
Brandon-w
Yukon
2015 Ram 1500
Just had a thought wondering why no companies have made an aftermarket overhead cam conversion for the hemis. I'm sure there could be some wicked performance gains from. Not to mention being able to pull more rpms and less lifter problems. [emoji48] Just my ramblings. Anyone have thoughts on this??
kurek
Northwest
That would necessitate an awful lot of large, precision parts (as in... heads, timing assembly...) and cost many thousands of dollars for questionable gains.
Or a person could just install a supercharged 6.2 or the SRT8 6.4 :)
Probably not a big enough market to justify the R&D costs,and as stated it would entail a whole new head casting/timing cover casting etc. and a chain probably 10 ft long,lol.Plus you'd need a blank cam in the original cam journals.It'd be cheaper to just stick a Whipple blown big cube 6.4 in instead,and probably upgrade to the newer 95 tranny
buddy guy
alberta
if indeed the rumours are true the 5.7 hemi is going away, we'll be lucky to have aftermarket parts, as it is!
RLJ10X
Southern Indiana
I'll bet Dodge keeps making the 5.7, 6.2, and 6.4 until it will no longer pass emissions. The cam is the big weakness in these engines.
The Pentastar has proven than they could make a very good overhead cam engine if they wanted. Just put 2, or better yet, 4 more cylinders on the Pentastar, and call it a day.
There's a pretty good chance that my 11 will need a cam, and everything that goes with it. Even if it doesn't, it'll always be on the back of my mind. But the flip side of all that is that I have money allocated for the new cam, and I'll put a little hotter cam into it if it comes to that.
Brandon-w
Brandon-w
Yukon
2015 Ram 1500
Yeah my 2015 is gona need a cam too. It's developed the lifter tick. I'll definately be putting a hot cam in it
What are you gonna put in it for a cam? Chris Zelinsky/Player 3 Performance Tuning in Edmonton is the local TSP cam dealer
kurek
Northwest
I think one of the biggest challenges there is size and weight. With full acknowledgement that they do sell a lot of trucks that justify the engine on its own, economy of scale is helped by the fact they can put the same engine in RWD cars and SUVs too. OHC/DOHC means much larger and heavier heads and since (properly balanced) V8s are 90 degrees that makes an OHC V8 a whole lot wider than a (properly balanced, 60 degree) OHC V6 even if they have the same bore and stroke. Making the engine wider and heavier limits what platform it can be installed in.
The 4.7 was OHC, but the largest displacement on that block was 4.7... that's a whole econo car engine smaller than a 6.4L hemi. On the topic of the 4.7, apart from the B.S. with the valve seats the HO version of that engine was really a quite good machine. A smaller, high RPM DOHC V8 would be cool to see but I doubt we ever will - much more likely to see either forced induction or more semi-hybrid powertrains like etorque. Nothing wrong with those.
It would not be good to make a Pentastar with 8 cylinders; a 60 degree V8 would be wildly imbalanced and require huge balance shafts and complex, fluid filled engine mounts to be acceptable in today's standards for NVH.
Brandon-w
Brandon-w
Yukon
2015 Ram 1500
I'm not sure yet. I'd like skme decent performance but don't Wana lose my decent towing but wana beat most trucks out there. I need to do skme research lol.
Slocab
Saskatchatoon Canada
Definitely hit up Chris. Those tsp cams are showing up strong on the dyno graph for where the powerband hangs out. I’d definitely say a stage 1 or 2 would be right up your alley.
Brandon-w
Brandon-w
Yukon
2015 Ram 1500
I like that. I goda go big or not at all haha. How's that switch workin for Ya?
RLJ10X
Southern Indiana
Kurek, it shouldn't surprise me that it's not as simple as just adding 2 cylinders.
Motorcycles have had over head cam engines, forever. If it'll fit in a motorcycle, surly they can get it under the hood of a Challenger.
Brandon-w
Brandon-w
Yukon
2015 Ram 1500
I was thinking external timing belts. And pulleys.
