overhead display problems
2002ramtruckowner
California
Hello Everyone
I'm new to this. Any help will be appreicated. I have a 2002 Dodge 1500 quad cab truck approx 1 year ago the over head display started coming on intertmittlely , now it does't come on at all. I've checked the fuses they are ok. Could it have somthing to do with the ignition switch? Or is it a wiring issue ?
thx
korby05
Delta, PA
5.9 Magnum
Is yours the evic one? If it's the evic one you can change some of your settings on the truck. Like your door lock settings, light delay plus other things.
The reason I ask is because if it is you cannot get the evic one even at the dealership. I have tried.
More than likely board fried on it.
Sent from my SM-G920V using Tapatalk
2002ramtruckowner
California
I'm not sure what a evic is. I'm guessing it's a type of computer board. If so you are probably right . I'm figureing out how to remove the console dsplay to have a look at the board. I have done a little research on the subject and found that the board does go bad. Not good news about the non stock statis of this part , my have to try local salvage yards Thank You for your help , I appreicate it and i'll kept you updated on my progress
2002ramtruckowner
California
I got the display out . a little tricky but not too bad. Yes my board is an Evic, am going to check salvage yards n the area thx again
HemiLonestar
Navy Badge Coast Guard
MD
It's probably the OTIS, not the actual EVIC (display looks like a calculator?). The base model OTIS version is a helluva lot easier to find.
2002ramtruckowner
California
I think mine is a EVIC . It says it right on the back of the module. I probley can get an OTIS and install it , but then I won't have all the features and optons. So i'm keeping my fingers crossed and hoping the salvage gods smile on me and I find one. The # on the back is 56045574AD. I haven't been able to figure out what the difference is between the different letters like an AD versis a AF of AE. Does anyone know ? This was used in other cars and vans in different years Any idea where I can get a list of these vechiles? It may help my chances of finding a replacement
Thank You
HemiLonestar
MD
AD is the initial part number, then they change the last letter (in order) as there are revisions or upgrades, change of vendor. Usually still completely compatible as long as the first 8 numbers are the same.
korby05
Delta, PA
5.9 Magnum
I went through all of this about 2 years ago. Went to the dealership gave them the part number and they sent me an Otis went back in they ordered another one to be sure and they said that the company that produced the evic is no longer around.
I actually found someone on the forums that had a working evic and bought it from them.
joshhhh
