P0108
waldropsk
Denver
Lately, only in the morning, the truck will have a very rough start. It was say "Service Electronic Throttle Control" and the CEL, Traction Control, and a blinking lightning bolt will come on. After about 10 minutes, I can turn the truck off/on and it will run fine, but with the CEL on. By the end of the day, no lights are on and it's running fine. The code it is throwing is the P0108 code and I have already replaced the MAP sensor. Any help or ideas is appreciated.
Burla
2010 Hemi Reg Cab 4x4
Hopefully this isn't one of those having to check the voltage at the wire things. Did you take off battery when you replaced map? For giggles, I'd clean the throttle body as well? Do a hard reset for more giggles. Wildone will ask is the sensor oem?
