It is POSSIBLE that the issue stems from something with the ECM, so it's POSSIBLE that it popped that code and is really an ECM issue vs a low temp issue. Not likely but it's a possibility. Best bet is to take it to a mechanic and let them diagnose it. If the code really is JUST for a low temp issue (cooling fan stuck on, thermostat failure, etc..) the truck should still run.
