Parasitic Draw from fuses M10 & M12
I Have A Truck
Delaware
5.7L V8
Help! I isolated the parasitic draw on my 2011 1500 Laramie to two fuses, M10 & M12. M10 is for the VES/SDARS/DVD/HFM/UGDO/VANITY and M12 is for the AMP/RADIO. Anyone else ever have a problem with this?
Shiva
Fairport
As asked above what is the draw? The radio and amp are always ready to go with preset stations and other memory. That requires a constant draw of power although small over time it causes problems with a weak battery. Your onboard computers are usually a larger loss of power.
Tach_tech
5.7L HEMI
Need to know the current draw of mV reading to know if it’s an issue. There will always be some draw.
Redmosq
Pa
I ran into this same problem with my 2012 1500. The draw is 1.34 is that significant?
Tach_tech
5.7L HEMI
Yes. When I pull out the fuse for the radio it drops to .6
1.34A is a pretty significant draw, even 0.6A is to high. Ideally it should be close to 0.05A.
Ftank
