YellowRam16
Hello all! I'm new to the forums. I was hoping someone out there could help me. I keep getting a parking lamp out message on my cluster. I've checked all of the lights and none are out. However, my left tail light does not light up when the truck is started/on. The Right side does, the 3rd brake light does but the left does not. So I changed the bulb with the same make/model and nothing changed. The brake light works when you hit the brakes but again when you are just looking at the tail light it is not on. The reverse light works as well. I even went as far as thinking maybe I got another bad bulb from a new package so I tried the bulb from the right tail light and no change, brake works, reverse works but no "driving light"
I have not changed out the socket yet for the brake light to see if that's the issue with the "driving light" but I wanted to see if you thought that could be the issue is the socket. Also if it's not the socket and it's the plug how can I go about fixing that?
Thanks so much in advance!
Oh and it's on a 2016 Canary Yellow Dodge Ram Hemi 5.7
