passenger axle will not slid out
Southern Vermnt
04 ram 2500 5.7L gas Hemi
I am replacing Wheel bearing and U Joint on the passenger side.
I have finally gotten the wheel bearing out, took a break knowing the axle should just slide out.
It won't slide out. When I did the drivers side, once the wheel bearing was out the axle shaft slide right out easily.
Am I missing something here?
Thank you,
Steve
