Passenger side mirror glass broken
utah01
Amsterdam, Netherlands
Hi, when backing up along my house I hit a steel post with my passenger side mirror. The glass is now broken. Checked with Mopar and a replacement mirror (heated, auto dimming) would cost me around $247. Anyone an idea of where to get an replacement mirror for less. Auto dimming isn't necessary, heated yes. I drive a 2014 RAM1500 Crew Cab Sport
Thanks for any suggestions
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Make sure the broken glass still responds to the motor movements. It's all plastic behind that glass. If it still works, be sure to use WD40 to remove the glass or you will break the motor.
Have a look at the turn signal camera thread for more details on mirror removal.
http://www.ramforum.com/showthread.php?t=64870
U
utah01
Just read your thread about installing camera in your mirrors. this will help me in dismantling the broken mirror.
Question on the camera's: How do you switch between the left and right side mirror camera? I do have the full Uconnect installed.
Bought in the meanwhile an ' el cheapo' replacement mirror on Amazon. Original would cost about 240 bucks replacement 18 bucks!
bigolayne
Springfield, MA
I have a lockpick installed so I can run front, rear, cargo, left and right side. On this setup there is a auto feature that does it when you hit the turn indicator and so on...
bigolayne
Springfield, MA
One of the others will need to chime in about doing it with just uconnect.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Not possible, the lockpick provides the ability to connect additional cameras.
