HaydenV
Hi, I have a 2008 1500 5.7 with code P0344 (Intermittent 5v signal to cam sensor). I'm thinking the issue is either in the PCM or the PCM connector considering my 5v to cam sensor is perfectly fine when it is warm outside. I've cleaned the PCM pins and connectors with electronic cleaner, which didn't resolve the issue. Is there a way to make a tighter connection? Or would this call for pcm replacement/splicing in a new 5v supply/other? Thanks for the help.
