AF_Hemi
- Jun 25, 2010
- 4,429
- 40
- 2013 Ram 1500 CC 4x4 Sport
- 5.7
I've got quite a few different ideas for colors for the new headlight projector retrofit. For the photoshop pros out there, if you'd like to help me out a bit i'd REALLLLLY appreciate it.
1. I'll be using my trucks current headlights, so the base picture needs to stay the base picture. I will be keeping the eyelids, the black painted surround, and the tinted markers.
2. I need the shroud/projector photoshopped into the bowl, and then different color patterns played around with.
Heres a couple of ideas:
- All black everything (both bowls, turn signal bulb cover thing, and shroud)
- chrome everything
- black headlight bowl/projector, chrome turn signal bowl/bulb cover
- chrome headlight bowl/projector, black turn signal bowl/bulb cover
- black bowls, chrome shroud, chrome turn signal bulb cover
- chrome bowls, black shroud/turn signal cover
again, the eyelids and current black will stay. the only thing that needs tweaked are the stuff inside the bowls (adding projector and changing colors). THANKS!!!!!
large projectors (size needs to stay the same)
mini-projectors (use to sample color for chrome perhaps? its the wrong size though --mini projector vs large projector)
- chrome everything
