I couldn’t get the Chrysler PIN Puller to work on my 2020 RAM, but I was able to change TPMS thresholds lower using alphaobd. About an hour later I left to try and get the PIN from the dealer, so when I started the engine, the low pressure TPMS alert was still displayed, but the tire pressures shown for each tire on the gauge cluster only showed two tires in red (all were now above the ‘inflate to’ pressure I had set). As I pulled into the dealer parking lot, I noticed the TPMS warning symbol had disappeared, and all four tire pressures were now shown in white (normal). So, I turned around and came home. No PIN, no reset RFH hub.
