TPMS Numbers Don’t Change
ACB8
ACB8
WA
2016 2500 Big Horn w/ Cold Weather Package
Have you checked for power directly at the RF Hub connector?
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 105756 miles.
I know my RF hub is receiving power because when I unplug it nothing works in the truck. Plug it back in and everything works.
ACB8
ACB8
WA
^Correct. The 16 still has a separate antenna for that function, that cable from the lower right runs over to a antenna module (TPMS antenna is still internal to the RF hub itself)
Where is the antenna module located? Thank you!
ACB8
ACB8
WA
ACB8
ACB8
WA
I’m pretty sure its still by the rear window
you can go to https://www.moparpartsgiant.com and look up the part and see an expanded view st the same time check your own vehicle’s compatibility
I don’t know if you have an iPhone but there may be an Android or Google version of this App
I downloaded the app but it needs the sensor IDs. When I use my OBD reader it does see the TPMS module so I can't get the IDs.
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
The tpms antenna on the 1500 is in front of the driver front tire. Small black box, with a 3 wire plug. I have never looked for it on a 2500
mtnrider
Georgia
It's the RF hub on his 2016. Hasn't been an antenna in the front since 2012 (or some time around then) on the HD trucks
ACB8
ACB8
WA
I took the RF hub apart and there was no water and no obvious issue. I checked the wiring for power and it has power. Not sure where to go from here.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Never mind that App is for a proprietary device that you screw into your valve stem it does not work independently just with the App
I just found and read the supporting documentation on their webpage
Mister Luck
WEST COAST
5.7 V8
The only module I have behind the seat is the RF hub. I dont have the other two and no plugs come out of the left side of the hub.
Mopar 56046958AA Antenna-Passive Entry
2013-2021 Mopar 56046958AA
You should have two of these one below the RF hub and another in a remote location that’s wire harness passes through the cab floor
Do you have a picture
behind your rear passenger seat of the cab wall ?
Mister Luck
WEST COAST
5.7 V8
Useful Information on module fuse location and relocation of antenna
OasisNinjaBat
