Plasti-Dipped Emblems Question
res1551cue
Scott AFB, IL
For those that dipped your Ram 1500 badges how did you keep the paint from getting between the letters? If you just painted them as is how did you get the paint out from between the letters and numbers?
chuck
Maryland
2013 True Blue Big Horn
You can use a razor blade to cut out the exact shape of painter's tape you need in order to put inside the lettering, or be lazy and do what I did. I just plasti-dipped everything, then used a razor blade to nick up the edge of the plasti-dip that was inside the lettering, then just peeled it out with my fingernail. I would recommend cutting out painters tape with a razor blade though. The way I did it was a huge PITA. There are some good youtube videos that show the best way to do it also.
chuck
Maryland
Anytime man, good luck.
chuck
Maryland
Sweet! Can't wait to see em'!
mossyoak03
portsmouth, va
Take a tooth pick and get it out. The plasti dip doesn't stick to the paint very well it will peel right off and it will stay on the badges.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I used a tooth pick
I had a blast peeling it from the paint
If you pull the right way you can pull it off as a sheet so you only have inside of the R and A
Stangshcky12
Oshkosh, WI
5.9 Cummins
3 heavier ones probably
If your looking for a smoother finish spray it a bit heavier
shostopper17
tooth pic for the small pieces but if u do the dip right it will remove perfectly peel slowly
res1551cue
res1551cue
Scott AFB, IL
Here's the passenger side. I think it turned out great. Thanks for the help guys.
Will post pics of the front ram head later this evening.
chuck
Maryland
Those all look great man. I really love the way they came out, especially against the red. Good work!!
Sent from my iPhone using Tapatalk 2
res1551cue
res1551cue
Scott AFB, IL
Thanks chuck. I'm happy about the way they turned out too. Now to just do the rear emblem.
chuck
Maryland
Anytime. And yea I split up the days I did my badges too, it just takes forever with doing that 30 minutes in between coats.
Bramo
