Please help, I have no brakes.
2001318help
Kentucky
I'm working on a 2001 dodge 1500. 5.2 4x4 manual trans. I bought it knowing it needed brake work to start with. That being said, here is the list of things I've done or replaced. New brake lines all the way from master to all 4 wheels. Including the rubber ones. New proportioning valve. New master cylinder, new booster, brakes, calipers, rotors and wheel cylinders and hardware. I have bled 2 gallons through it and the pedal still goes to the floor. I bled them in the correct order and made sure to keep fluid in the master. All new parts. Nothing bought is remanufactured. I bench bled the master as well. I have and light and brake light on dash. When driving the pedal goes instantly to the floor with no resistance, once the pedal is fully depressed, the front brakes lock up..
atom13
USA
Na
Na
May have to actuate abs module. Does it hold pressure when pumped with engine off?
SYKRAMMAN
Banned
Jersey shore
06 Mega
^this^ yeah the abs has to be actuated to be bled, needs to be done with a scanner that supports that feature.
Sweeney
Baltimore, Md
ive also seen the vacuum check valve that’s on the brake booster fail and cause the same issue. Might be worth looking into, super simple test, pull it out and try to blow through both sides, you should only be able to blow through 1 side.
EvilSpirit
5.9 Magnum
How aggressive is your rear brake adjustment? For the most part, the rear drums set pedal height. I would make sure the rear brakes were installed and adjusted correctly - I like to see a light drag on them during rotation - before I went any further.
Reticle918
