Help Support Ram Forum by donating:
Power Folding Mirrors Sticking
Discussion in 'Exterior' started by crakerjac, Jan 14, 2020 at 11:17 AM.
Sponsored By: BAK Factory Outlet
  1. crakerjac
    crakerjac Junior Member
    36
    Jul 26, 2019
    Minnesota
    Ram Year:
    Engine:
    I tried searching, but came up with nothing.
    I have a 2017 1500 Sport with power folding mirrors from the factory. It seems that the passenger mirror doesn't always want to fold in. It's sticking/catching somehow. If I get out of the truck and wiggle the mirror a little, the mirror will fold in/out just fine. It will continue to work fine for a couple days, but if I go a week or so without using the folding option, it will stick again. It's January in Minnesota, so it could have gotten water in it and froze over, but it did the same thing in August when it was well above freezing.
    Any ideas what's going on? I don't think it's the control module as I can see the mirror 'try' to fold in and give up.
  2. gofish101
    gofish101 Senior Member
    106
    83
    Dec 11, 2012
    Ram Year:
    2018 Outdoorsman CC
    Engine:
    Same thing with mine. Odd it's just passenger side for me as well. Be interested if there is a fix.
  3. billyw
    billyw Senior Member
    264
    89
    Jul 1, 2016
    Northwest
    Ram Year:
    Engine:
    I just had this happen on my passenger side mirror too. It came in about 1/2" maybe. I opened them out again, then closed them and it worked fine.
  4. madtrucker2016
    madtrucker2016 Senior Member Supporting Member
    1,268
    632
    Apr 21, 2019
    New York
    Ram Year:
    Engine:
    Mine does that too. pisses me off then I got to get out of truck to push it in place. seems to work fine 95 percent of time ,but then it happens. I had a thought that maybe it was pushed or moved when I was not in the truck,and then when I go to use it its stuck. and I get pissed off again Lol
  5. Kalill Nieto
    Kalill Nieto Senior Member
    46
    171
    47
    Jan 28, 2018
    Fort Lauderdale
    Ram Year:
    Engine:
    Maybe try to add some oil somewhere inside in the mechanism?
  6. crakerjac
    36
    Jul 26, 2019
    Minnesota
    Ram Year:
    Engine:
    That's my thought. Spray some WD-40 (or some REAL lubricant), into the unit... but I don't know enough about it to know where to start spraying.
  7. RamCares
    RamCares Senior Member
    2,298
    923
    Jan 21, 2016
    Ram Year:
    n/a
    Engine:
    n/a
    Hello crakerjac and gofish101,
    We are certainly sorry to hear about your recent concerns. As our team is not technically trained, we are unfortunately unable to speculate regarding this inquiry. With this in mind, I kindly suggest connecting with your local dealer, as they are in the best position to assist. If you do decide to work with a dealer for this concern, please reach out to us if you need any additional assistance throughout that process.
    Laura
    RamCares
  8. crakerjac
    36
    Jul 26, 2019
    Minnesota
    Ram Year:
    Engine:
    If it's something that's covered under warranty, I'll have the dealer look at it. If not, I'll take some time and figure it out myself (or just deal with it).
  9. Valkyrie0002
    Valkyrie0002 Junior Member
    60
    20
    10
    Apr 1, 2019
    Fredericksburg, Va
    Ram Year:
    2017 Big Horn CC
    Engine:
    Mine has frozen closed on a couple cold mornings and I had to bump it to free it. I want to spray a little silicone in the joint because its cleaner. WD is pretty thin- maybe one of the specialty WD would work better.
  10. Kalill Nieto
    46
    171
    47
    Jan 28, 2018
    Fort Lauderdale
    Ram Year:
    Engine:
    I think that wd40 is not the best choice. I will suggest oil or silicone spray
Share This Page
