powerwire
LoadedLaramie
Columbus, IN
any one have a power wire on there 4th gen? thats not homemade? i know a couple people on DT do but cant seem to find my answer, i bought one and the connectors are differant from the 3rd gen rams so it wont fit, i tried shaving a tang off and it goes in but the inner block is differant sizes too.
any input is appriciated
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I have the one that was on my 08 on my 10. No issues........but its not one of the "new" models though with the super special connector Nick puts on them now.
L
LoadedLaramie
Columbus, IN
any chance you could take a pic of what your talking about?
why is it so special? does it have both options in the groove patterns?
my connectors are completely different form each other.
the powerwire adds fuel at WOT so your engine doesn't run lean like it tends to do if you watch your A/F ratio while you slam the hammer down.
what it actually does it trick the PCM to think the incoming air temp is about 20* cooler than it actually is so it adds a bit more fuel. alot of 3rd gen guys run them and most say with headers they run lean and the PW helps it balance better.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
mine:
new one:
L
LoadedLaramie
Columbus, IN
Ah ha.... i guess i have the new one and its spefic to the 3rd gens. Looks like ill be doin a bit of modding on my mod to get it to fit. thats ok. got my sonnax in and i needa tweak my tune a bit too so ill do it all at once.
thanks jeremy.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
What are you using as a tuner on it and what other mods do you have? If your getting custom tunes from a tune writer the power wire wont be needed becuase the files are made to acomplish what that already does.
L
LoadedLaramie
Columbus, IN
I was talking about tweaking my trans points.
I run the 91 tune and wen i get my t-stat in and pw in ill change it to 93 just so it wont run lean.
