- Joined
- Feb 7, 2020
- Posts
- 945
- Reaction score
- 1,739
- Location
- Greater Cincinnati area
- Ram Year
- 2014
- Engine
- 5.7 Hemi
I replaced pads/ rotors all the way around on my Ram (1500, 4wd) and went back in to look at everything due to some brake noise and discovered one piston on front pass side caliper is just a little oozy.
So to play it safe I was thinking about replacing all 4 calipers (119k on truck).
I've actually never replaced calipers myself, I do understand the basic procedure.
Here's the dumb q: I don't have a lift so I do one wheel at a time. Can I replace one caliper, bleed it, go to the next, bleed etc.? Will I need to go back and bleed again if I do that? Or is it better to replace all 4 then go around and bleed?
Many thanks!
Many thanks!
