duster72
- Aug 14, 2025
- 2
- 10
- Location
- British Columbia, Canada
- 2012
- 6.7 Cummins
I noticed that there seems to be many guys on here having problems with their cruise not working. Mine was also not working, and was having the same issue as many of you. As in no cruise icon on the dash when I pushed the switch on the steering wheel. I found out that the brake pedal was not pushing the brake switch plunger back far enough when the pedal was released. This caused the cruise to think I still pushing the brake pedal. Funny thing was my brake lights were working properly and only activated when I pushed the pedal. Kinda weird and I never did figure out why the brake lights worked the way they were suppose to but the cruise did not. Anyway, to fix the problem all I did was found a rubber cap to snap on over the brake switch plunger. By adding the rubber cap, it made the pedal push the plunger on the switch back further when the pedal was no longer being pushed. The cruise icon was back and I am now able to set the cruise. Just thought I would share and hope it helps some of you.
