alainwow
hello, so I recently purchased the 2019 style modifystreet v2 headlights with the katana h7 lowbeams. I have a 2015 1500 once installed I turn the headlights on and they function, turn on, everything looks good. Once the ignition is turned on the driver side headlight flickers twice and dies (low beams only). I simply disconnect the led from the driver and plug it in the passenger and it works fine. Swapped bulbs and drivers and the passenger works fine, but the driver is completely dead. At this time I went to a buddies house popped out the multimeter and found out that the low beam driver side is not getting any power. Oddly enough disconnecting the battery and reconnecting it’s few seconds later and it’s functional, with a halogen h7, plug in the katana and it dies again with no electricity doing to the low beam. My first led lights I purchased at superbrightleds (rookie mistake) purchased a harness adapter and they work perfectly fine. Does anybody know what is going on and how it can be fixed? Also the 1/2 inch gap the headlights have on the bottom sucks!!!
