Boosted Motorsports
- Nov 2, 2011
- 467
- 425
- 2014
- 5.7 Hemi
Found a simple solution for the notorious ProCharger belt slip issue and not producing full boost. The carbinite treated supercharger pulley process strips the shiny smooth anodization off the contact area of the belt and then treats it with a "grit" surface that grabs the belt. Lots of other people using this on other applications but I haven't seen anyone try this on our rams.
I was seeing max 5-6psi with overtightening the belt before. With standard recommended procharger belt tension I'm now seeing full boost of 7-8psi.
Check out these 3 videos on my channel to see the process
I feel we are both at about the same process for our kits. When I had mine tuned I told my tuner I wanted to be around 500 whp and he did on 6lbs and that is why I only run that much. So maybe with that coating I would be running more boost and more hp?
