Programmer and Delete Kit Suggestions ?
Jhuge
Mississippi
Cummins 6.7
Programmer Suggestions ?
Any suggestions for the tuner // Exhaust combos to use on the 2014 6.7 3500 ?
Power247
High Point, NC
6.4 HEMI
For tuning I recommend MM3 with custom tuning from Double R Diesel. I have about 60,000 miles on my Flo Pro delete pipe and still going strong.
Greg
2012 | RAM 2500 | CCSB | Custom tuned by Double R Diesel
2016 | Heartland Pioneer | DS310
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Going with draconian performance myself, but yeah the mm3 with trans tuning is a solid program. 4 or 5 inch, doesn't really matter too much which one. 5 is deeper, 4 a little less drone. You gonna remove the EGR, or just turn it off?
MADDOG
Living in a Firepit
6.4L HEMI
Here is my list of delete, tune & transmission mods done. You probably don't need the unlock as your PCM is open for tuning.
Delete & Tune mods:
Edge CTS-2 Insight with Cummins unlock
13 – 17 EFI Live Dodge CSP4 tune package by PPEI / Kory Willis
13 – 17 EFI Live Dodge transmission tuning
Cummins tuning switch CSP5
EGR valve and cooler removal with block off plate
Throttle valve delete
FloPro catalytic converter & DPF delete pipe, 4”
4” – 6” black exhaust tip with rolled edge
Edge expandable EGT probe kit
Pillar pod mount for Edge CTS2
Transmission mods:
BD Diesel 68RFE valve body plate kit
Mag Hytec deep transmission pan
ATS 68RFE transmission case support brace
I am still straight piped - yup, the Magnaflow was removed - and I am not sure what I will be doing there yet.
Trupiano
Registered User
6.7L CTD
I don't believe so. I've heard the EGR can help with exhaust drone a bit, and unless one of the valves fails, it should be just fine. Now, if your going for more performance, it might be in the way of a new intake manifold or larger turbo or things like that. Also, if you decide to delete the EGR, I believe you'll want to get a coolant bypass hose so the coolant can still get back where it needs to.
SouthTexan
408 CTD
My EFIbyRyan is through Hardway Performance and my exhaust is a turbo back Flo-Pro 5" with muffler and a 17" FTE resonator. The tune makes the EGR inoperable so you don't have to remove it if you want, but you must remove the DPF. If you leave the EGR intact then you will not need a resonator since the EGR cuts down a lot of the drone. If you do remove the EGR then I would get a resonator because the drone will be horrendous.
I don't have to remove the EGR, but I did notice a slight improvement in turbo response due to exhaust no longer having to flow through the EGR cooler. The other benefit of removing the EGR was that the block off plate had a tapped hole for an pyrometer so I didn't have to drill and tap a hole in the manifold to monitor EGT's.
J
Jhuge
Mississippi
Cummins 6.7
Great info all !
I only have 47000 right now but I intend to delete the truck around 80000.
I figured you would have the down and dirty on this topic !.
Thanks a million !
leeroy300
BC Canada
2020 Laramie Sport
6.7 l
what would the cost of all the parts be and how to get them in Canada?
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
Im running a EZ Lynk with tuning from starlite diesel. No complaints and definitly an advancement over having to have a dedicated digital gauge pod and a EFIlive tuner.
