- Mar 17, 2016
- 516
- 478
- 2020
- L6 Diesel HO
On my new 2020 Ram 3500 I have the factory puck system. I also received the Mopar M25 5th wheel hitch with my truck. I followed the directions for the install and all went well. I removed the hitch to use the truck bed and it was tight, but removed with out tools or pry bar.
Reinstalling I used a chain fall. But I was not directly under the chain fall, Off by a couple of inches. So I wasn't perfectly straight going in. And I had issues re-installing the hitch.
I will have time this evening again to play with the hitch. Are these hitches so close in tolerance to require a very close alignment to "drop in". Once in, the handle close easily, with a slight resistance.
What have y'all found?
